Hello, I'd like to know if there is any difference in encoding quality using latest libx264 on Linux or using x264 on windows. Both at the latest upstream update, and both with the same parameters. Will I get better results with windows? How better, and why?
I've the same question for audio encoding, so if I use latest codecs in linux+ffmpeg and latest codecs in windows+eac3to, will I get better encoding results in windows?
In general: No, x264 is just a separate command line interface to exactly the same libx264. You can use ffmpeg the same way in both Linux and Windows.
A difference in detail might be how your source video is handled before the encoder core receives its video stream. But in most cases it should be identical.
Regarding audio: Well, yes, eac3to may behave differently, compared to ffmpeg.
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2524Last Post: 15th Jul 2026, 12:00 -
how do i add libx264 and hevc to ffmpeg when i compile ffmpeg for ubuntu 21
By oduodui in forum Newbie / General discussionsReplies: 2Last Post: 17th Jul 2021, 04:12 -
Cannot encode video with ffmpeg libx264 maintaining 5 reference frames.
By Budman1 in forum EditingReplies: 4Last Post: 20th Aug 2020, 13:27 -
Is there somewhere I can download FFMPEG with x264 for Windows 7 64bit?
By Livingonvideo in forum Newbie / General discussionsReplies: 2Last Post: 16th Jan 2020, 19:13 -
libx264 is no longer available in ffmpeg?
By oduodui in forum LinuxReplies: 2Last Post: 17th Feb 2019, 13:49
